  4. ABB Robot Forum
Tool Data (Help)
  • Dodo41
  • February 1, 2024 at 11:49 PM
  • Dodo41
    64
    Hello everyone, friends. There is an extension pipe after the flange on one of my transport robots, and a Gripper is connected to that pipe. Robot and Gripper are used for picking and dropping parts from the table. The dimensions of the gripper are as seen in the picture. Its weight is 2kg. . I want to create a tool and apply TCP to it. What do you think the most appropriate data should be?
  • Dodo41
    64
    • February 1, 2024 at 11:52 PM
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • February 2, 2024 at 2:00 PM
    It looks like that comes straight out from the faceplate. If so, the distance from the end of the faceplate to the center of the gripper should work well.
  • Dodo41
    64
    • February 2, 2024 at 3:58 PM
    What values should I write to the Tooldata data?
  • Viperacebb
    5
    26
    • February 22, 2024 at 10:13 PM
    It looks like you are using RobotStudio. If so, this is fairly easy. Go to the Home tab - Other (drop down) and create tool data. This is where you would input the data that you're looking for. Based on the picture, it looks like it's straight off the flange, so you would be putting a + value on the Z (as Z comes straight off the flange). You should also put the weight into the system in kg (i.e. 2 for 2kg). Depending on the year and model, I would also suggest running the Load ID with the tool and another with tool and load (i.e. part). This would help with using collision detection and can be fine tuned to eliminate bad crash problems. I hope this helps!
Similar Threads
  • Problem with importing programs into KRC
    • Uros Marinkovic
    • September 9, 2023 at 4:18 PM
    • KUKA Robot Forum
  • Bringing robot safely to home position
    • jinesh8888
    • February 4, 2023 at 2:11 PM
    • KUKA Robot Forum
  • kuka krc2 TCP deviates while moving in ABC world.
    • kishan
    • December 20, 2022 at 2:40 PM
    • KUKA Robot Forum
  • Clarification of robot terminology Tool Frame vs TCP
    • Askic
    • November 2, 2022 at 12:34 PM
    • Robot Geometry, Linear Algebra, Forward and Inverse Kinematics
  • Nonsensical TCP behavior
    • Wall-E
    • February 7, 2022 at 2:29 PM
    • KUKA Robot Forum
  • Load Data Tool problems.
    • foffulaRob
    • December 3, 2021 at 3:56 PM
    • KUKA Robot Forum
  • Tool coordinates questions
    • Jerryl859
    • October 21, 2021 at 5:03 PM
    • Kawasaki Robot Forum
  • Fanuc Vision Accuracy Help
    • Zompolas
    • July 30, 2021 at 6:52 PM
    • Fanuc Robot Forum
  • Method of automatically adjusting tool data
    • plowry
    • February 18, 2021 at 6:26 PM
    • ABB Robot Forum
  • Load data vs. point reach accuracy
    • dgrzywnowicz
    • December 28, 2019 at 9:07 PM
    • KUKA Robot Forum
