Many of times I went into discussion if completing Load Data Determination is crucial in improving point reaching accuracy of robot.
Just to be clear, I am aware of a neccessity of performing LDD in aspects of improved motion planning and lifetime of servos etc (and I always complete LDD), but I am pretty sure, that Load Data is only regarded in dynamics of robot, and has nothing to do when it goes about statics.
Let's assume that we have two same robots with the same tool, f.e. 160kg servo gun. Both robots have tool offset teached. On the first robot load data determination was performed, and the second one is without LDD.
Then we calibrate base with those heavy tools mounted on flange, using Indirect method (4 points, entering coordinates from plate). Are we gonna have difference in quality of those calibrations between those two robots, or not?
Below I attach quote from KSS8.2 SI Manual:
Quote5.11 Load data
The load data are factored into the calculation of the paths and accelerations
and help to optimize the cycle times. The load data must be entered in the robot
controller.
