Karel Build Failed: ????-598 $ 182256, no message found
  • boriskostov
  • January 16, 2024 at 3:11 PM
  • boriskostov
    5
    50
    Has anyone had the following error:
    *** Translation successful, 93 bytes of p-code generated, checksum 7523. ***
    0x100016 - File untitled1.pc
    Everything was ok, and at one moment the error occurred!
  • Nation
    Typical Robot Error
    553
    1,935
    • January 16, 2024 at 3:48 PM
    Try deleting the .pc and .vr file from the controller, and recompile.
  • hoitzing
    24
    128
    • January 17, 2024 at 7:59 AM
    That is what I get when I try to build a KAREL program in Roboguide that is also currently selected on the roboguide TP. Simply selecting another program is enough, no need to delete the program (*.pc or *.vr) that is only needed if you want to change array lengths or make named variables a different type than before.
  • boriskostov
    5
    50
    • January 17, 2024 at 12:45 PM
    The problem is solved. The name of .kl files was too long.
  • ali alp
    8
    • January 23, 2024 at 11:08 AM
    I have a fanuc s420f robot and r-j panel. For this, I code the program in Karel languages. But while converting this karel file to .pc format, it builds with ktrans v9 version. When I transfer the file we created with this version to the r-j panel, I get the 'version too old' error. what should I do for this.
    The roboguide simulation program I use does not have r-j panel support.
    How can I downgrade the ktrans version? Or how can I transfer the file to the r-j panel?
Similar Threads
  • " INTP-311 (MODIF_TCP, 84) Uninitialized data is used"
    • i_robot72
    • September 30, 2021 at 9:06 AM
    • Fanuc Robot Forum
  • Karel build
