" INTP-311 (MODIF_TCP, 84) Uninitialized data is used"
  • Hello everybody,
    I new in Fanuc, especially in karel (lol).
    I get an issue during the execution of the routine below at the line 84:
    There is no any problem of building, only when i execute.
    I tried many different ways to initialise the variable "xyz_TCP_Set" but i did not success.
    Is anybody here having a solution for my problem ? Thanks ahead.
    PROGRAM Modif_TCP
    -- PROGRAMME Modif_TCP --
    --Mettre la variable $KAREL_ENB à 1 pour pouvoir selectionner un programme KAREL
    %ALPHABETIZE -- Specifies that variables will be created in alphabetical order when
    -- p-code is loaded.
    %COMMENT = 'SET TCP PINCEBATTEUR' -- Specifies a comment of up to 16 characters. During load time
    --, the comment is stored as a program attribute and can be displayed
    -- on the SELECT screen of the teach pendant or CRT/KB.
    %NOLOCKGROUP -- Specifies that no motion groups will be locked by this task.
    %NOPAUSE =ERROR + COMMAND + TPENABLE -- option Specifies a set of conditions
    -- which will be prevented from pausing the program.
    %NOPAUSESHFT -- Specifies that the task is not paused if the teach pendant
    %INCLUDE klevccdf -- Character code constants : CHR()
    VAR
    xyz_TCP_Ref : XYZWPR
    xyz_TCP_Set : XYZWPR
    Pose_Modify : XYZWPR
    PR_value: XYZWPREXT
    i_NumToolRef : INTEGER
    i_NumToolSet : INTEGER
    i_Num_PR : INTEGER
    st_NumToolRef : STRING[1]
    st_NumToolSet : STRING[1]
    -- Pour lecture paramètres
    i_val : INTEGER
    r_val : REAL
    st_val : STRING [1]
    i_Status : INTEGER
    i_Entry : INTEGER
    b_Flag : BOOLEAN
    BEGIN
    --Lecture paramètre entrée routine
    --GET_TPE_PRM(param_no, data_type, int_value, real_value, str_value, status)
    --data_type=1 >> int_value
    --data_type=2 >> real_value
    --data_type=3 >> str_value
    --Conversion entier en string
    --CNV_INT_STR(source,length,base,target)
    --source >> integer
    --length >> minimum length of target
    --base >> 0 if (base)10 , between 2-16
    --target >> string destination
    --param 1 : Read TCP Ref number
    GET_TPE_PRM(1,1,i_NumToolRef,r_val,st_val,i_status)
    CNV_INT_STR(i_NumToolRef,1,10,st_NumToolRef)
    --Read TCP Ref
    GET_VAR(i_Entry,'*SYSTEM*','$MNUTOOL[1,'+st_NumToolRef+']',xyz_TCP_Ref,i_Status)
    --param 2 : Read TCP Set number
    GET_TPE_PRM(2,1,i_NumToolSet,r_val,st_val,i_status)
    CNV_INT_STR(i_NumToolSet,1,10,st_NumToolSet)
    --Read TCP Set
    GET_VAR(i_Entry,'*SYSTEM*','$MNUTOOL[1,'+st_NumToolSet+']',xyz_TCP_Set,i_Status)
    --param 3 : Read PR with transform values
    GET_TPE_PRM(3,1,i_Num_PR,r_val,st_val,i_status)
    PR_value=GET_POS_REG(i_Num_PR,i_Status)
    --Affect Pose_Modify
    Pose_Modify.X=PR_value.X
    Pose_Modify.Y=PR_value.Y
    Pose_Modify.Z=PR_value.Z
    Pose_Modify.W=PR_value.W
    Pose_Modify.P=PR_value.P
    Pose_Modify.R=PR_value.R
    --TCP Transform
    xyz_TCP_Set = xyz_TCP_Ref:Pose_Modify >>------------------------------------------------>>" INTP-311 (MODIF_TCP, 84) Uninitialized data is used"
    --Write TCP Set
    SET_VAR(i_Entry,'*SYSTEM*','$MNUTOOL[1,'+st_NumToolSet+']',xyz_TCP_Set,i_Entry)
    END Modif_TCP
  • hi
    thanks for the reply is uninitialized because of 2 issues :
    -xyz_TCP_Ref has to be a position (apparently, with this data type i can get tool value not with XYZWPR datatype)
    -st_NumToolRef is equal to ''
    This gets me to another issue:
    >>CNV_INT_STR(i_NumToolRef,1,10,st_NumToolRef) does not work
    >>i can not set a string greater than 1 in the VAR declaration area ?????
    each time i tried, i get the following message:
    "Build Failed: ????-598 $ 182256, no message found
    0x100016 - File modif_tcp.pc"
    Can u help me please ??
    here is the new code:
    PROGRAM Modif_TCP
    %CMOSVARS
    VAR
    st_Utool_Ref : STRING[1]
    st_Utool_Set : STRING[1]
    Utool_Ref : POSITION
    Utool_Set : POSITION
    Utool_Tr : POSITION
    PR_value: XYZWPREXT
    i_Num_PR : INTEGER
    bMAP : BOOLEAN
    i_val : INTEGER
    r_val : REAL
    st_val : STRING [1]
    i_Status : INTEGER
    i_Entry : INTEGER
    b_Flag : BOOLEAN
    ROUTINE EFFACE_ECRAN
    BEGIN
    WRITE (CHR(128),CHR(137))
    WRITE TPERROR (CR,' ',CR)
    WRITE TPSTATUS(CR,' ',CR)
    WRITE TPPROMPT(CR,' ',CR)
    WRITE TPFUNC (CR,' ',CR)
    FORCE_SPMENU(TP_PANEL,SPI_TPUSER,1) -- Force ecran sur USER
    END EFFACE_ECRAN
    BEGIN
    EFFACE_ECRAN
    bMAP = TRUE
    --param 3 : Read PR number
    --Read Tool Ref
    CNV_INT_STR(i_NumToolRef,1,0,st_Utool_Ref)
    st_Utool_Ref='1'
    GET_VAR(i_Entry,'*SYSTEM*','$MNUTOOL[1,'+st_Utool_Ref+']',Utool_Ref,i_Status)
    IF (bMAP=TRUE) THEN
    WRITE ('Utool_Ref:',Utool_Ref,CR)
    ENDIF
    --Read Tool Set
    CNV_INT_STR(i_NumToolSet,1,0,st_Utool_Set)
    st_Utool_Set='1'
    GET_VAR(i_Entry,'*SYSTEM*','$MNUTOOL[1,'+st_Utool_Set+']',Utool_Set,i_Status)
    IF (bMAP=TRUE) THEN
    WRITE ('Utool_Set:',Utool_Set,CR)
    ENDIF
    --Read PR value
    IF (bMAP=TRUE) THEN
    WRITE ('PR_value:',PR_value,CR)
    ENDIF
    --TCP Transform
    Utool_Set = Utool_Ref:PR_value
    WRITE (Utool_Set,CR)
    --Write TCP Set
    SET_VAR(i_Entry,'*SYSTEM*','$MNUTOOL[1,'+st_Utool_Set+']',Utool_Set,i_Status)
    WRITE ('i_Status=',i_Status,CR)
    END Modif_TCP
  • in fact, each time i set a string greater than 1 (eg str_tmp : STRING[5]), the problem is that i can not build the .pc file under roboguide, even i delete on the controller ....
  • I see what you mean now.
    That is weird. I would look in the KAREL user manual for an example that uses STRINGs. Copy the example into a new program and try to build it. Verify that you use the user manual that matches your version of the KAREL compiler.
  • you were right... I have copied the code in a new one, i succeed to modify a string size in the var area . The build was ok and after test in the controller it works very well....
    It was a latent bug in roboguide, amazing....
    really thanks for ur help.
