KUKA Insert the Recovery USB drive into the control cabinet, turn on the power, press the F10 button, and prompt F10 key detected. Wait for a while to display the Missing operating system. Is it Windows that does not have an activation license?
KRC2 KUKA Recovery of USB system image
wangyichao -
January 7, 2024 at 3:59 AM -
- Go to Best Answer
your recovery stick is not really a recovery stick. it is not bootable.
The KRC4 control cabinet is in normal use, version 3.0.2, and it can be confirmed that the USB drive is good
all right then, so the stick is good. did you check the usb recovery stick manual for requirements? copy fo the manual should be on the stick itself.
your KRC2 many not be able to boot from it. if i recall requirements include that bios is above certain version, usb support is enabled etc. also krc2 must have at least 512kb RAM
What I can confirm now is: BIOS V4.06 R1.05-08.1688.01. RAM 512MB, as for whether USB booting is supported, I cannot determine. How should I determine?
Here are the hints from the manual, USB has to have legacy support enabled in the BIOS.
BIOS V4.06 R1.05-08.1688.01 supports USB (KR C2 edo5)
I don't know where the problem is? Is this related to booting a USB drive
- Best Answer
what is the version of your USB Revery Stick?
I have used v1.x and 2.x on KRC2 without issues. don't think i had chance to use newer ones.
V 3.X,
But I remember the v3. x manual states that it can be used in KRC2
According you post #9: you do not have the requested 512 MB as requested in post #5
512MB was indeed written on the running memory module
