Hello Everyone,
I want to see if there is a way to talk to the FS010N with a S51+ controller using Notepad++. I have used KcTerm with the robot and was able to extract positional data but wanted to try something different.
Thanks,
Hello Everyone,
Thanks,
Welcome to the forum............
Plenty of flavours found here including Notepad++
Awsome.
I was able to talk to the robot. was able to get some string data out.
Next i want to talk to the robot using a python script.
any pointers?
I tried to write a script and check if the port is open or not and I received,
"Successfully sent data to 192.168.1.0 on port 23"
How to I send the "as" for the login and receive further replies.
import socket
def send_data(ip_address, port, data):
# Create a socket object
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
try:
# Connect to the device
s.connect((ip_address, port))
# Send data
s.sendall(data.encode())
print(f"Successfully sent data to {ip_address} on port {port}.")
# Close the connection
s.close()
except Exception as e:
print(f"Could not send data to {ip_address} on port {port}. Error: {e}")
send_data("192.168.0.1", 23, "as")
Thanks,
Display MoreAwsome.
any pointers?
Code Display Moreimport socket def send_data(ip_address, port, data): # Create a socket object s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) try: # Connect to the device s.connect((ip_address, port)) # Send data s.sendall(data.encode()) print(f"Successfully sent data to {ip_address} on port {port}.") # Close the connection s.close() except Exception as e: print(f"Could not send data to {ip_address} on port {port}. Error: {e}") send_data("192.168.0.1", 23, "as")
Thanks,
Hello!
Try this repository to get an example of python communication with Kawasaki robots
