Using UOP signals Via Modbus TCP
  • Valenti
  • December 20, 2023 at 10:54 AM
  • Valenti
    Hi, I'm new to the forum. I'm trying to communicate a Fanuc Robot with R30iA controller and V7.7 Firmware with Modbus TCP to a Siemens 1512C (all real hardware, no simulation). With DI/DO I can do it, but with UI/UO signals I can't. Reading the manual seems that Modbus only works with D//DO and GI/GO, but if I map the UOP signals to rack 96 (Modbus) it allows me. Do you know if it is possible? Thanks in advance.
  • MOM December 20, 2023 at 10:55 AM
    Approved the thread.
  • DS186
    200
    1,075
    • December 20, 2023 at 11:27 AM
    Mapping the UIs and UOs to rack 96, slot 1 should also work.
  • HawkME
    570
    3,269
    • December 20, 2023 at 2:40 PM
    UI/O, UI/O, and GI/O are all the same as far as configuration. They are simply a point or range of points of IO.
  • DaveP
    23
    201
    • December 22, 2023 at 4:21 PM
    You can also map the UI/UO to Flags and then use background logic to assign DI/DO to the flags. One nice thing is that Flags can be mapped as an input or an output.
  • Valenti
    • January 17, 2024 at 7:23 PM
    Thanks a lot, I didn't connect till now and I haven't seen your answers. I solved it. My problem was that in Modbus TCP configuration I had only 2 input and output words and I wanted to map 16DI/DO plus UI/UO which are 18 and 20... so more that 32. Finally I put 3 words and problem solved.
  • Timmi7994
    • March 6, 2025 at 7:52 PM
    Quote from Valenti
    Hej, maybe you are able to support me with simmilar issue?
Similar Threads
  • stoping and resuming movement using UI signals
    • zahid990170
    • June 15, 2021 at 4:50 PM
    • Fanuc Robot Forum
  • R30iA
