Analog Input-Output Profinet
  • mesicki
  • December 18, 2023 at 5:51 PM
  • mesicki
    15
    Hi
    I am new on this forum, and need help about analog inputs and outputs maping over profinet cp1604.
    I have digital IO working but can not find the way to set analog :thinking_face: .
    Controler is Fanuc 30iB plus,profinet is configured like (I device)...GSDML file etc .
    PLC is SIEMENS S7 1200.
    Regards
    Zoran
  • kwakisaki December 18, 2023 at 5:59 PM
    Approved the thread.
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum.
  • mesicki
    15
    • December 19, 2023 at 6:41 PM
    Anybody?
  • Nation
    Typical Robot Error
    542
    1,924
    • December 19, 2023 at 7:04 PM
    I don't believe it is possible over Profinet. AI and AO is intended for analog input and output cards sold by Fanuc.
    Have the PLC send the analog value over a GI, or you send it over GO.
  • mesicki
    15
    • December 19, 2023 at 7:32 PM
    In fact, I was thinking of sending a real or integer number via Profinet to plc and vice versa.
    I thought it was the only way possible, through analog inputs and outputs.
    Any ideas?
  • pdl
    270
    1,533
    • December 19, 2023 at 7:59 PM
    Follow Nation's advise. Use Group I/O to send and receive integers.
    Analog I/O is reserved for Fanuc's analog hardware.
  • mesicki
    15
    • December 19, 2023 at 8:21 PM
    Now I understand
    Thanks a lot.
  • pdl
    270
    1,533
    • December 19, 2023 at 8:40 PM
    One last thing, group I/O, by default, uses two's complement to encode positive and negative values.
    It is not mentioned in Fanuc's documentation, at least not that I can find, so it is worth mentioning.
  • mesicki
    15
    • December 19, 2023 at 8:42 PM
    :smiling_face: :thumbs_up:
