Robot On A Rail Questions
  • Iprogram
  • November 1, 2023 at 4:17 PM
  • Iprogram
    148
    I have not worked with a robot on a rail yet and starting to set it up in Roboguide. I want to use Group 2 of the robot but wondering what the best way to set this up would be? The robot will be picking from different bins along the rail and i want the motion to be smooth and look fluid without any waisted motion. i have the multigroup option and also extended axis options
    When setting this up in roboguide what is the best option to pick while configuring the robot? should i choose Basic Positioner, General Positioner, Independent Axes, or Rail Unit? And how do these choices get setup in the real robot?
  • pdl
    266
    1,509
    • November 1, 2023 at 7:29 PM
    Why do you want to use two motion groups?
    Usually you would setup the rail as an extended axis in your application.
  • retobor
    17
    202
    • November 1, 2023 at 9:24 PM
    I always highly suggest extended axis. Avoid Group 2 if you can.
    1. DCS is a nightmare if your rail is setup for group 2. Fencelines/operator spaces move with the robot.
    2. Any type of frame shifting/ work in cartesian space is a nightmare because the robot doesn't know its moving when the RTU is moved.
    3. If you have to reposition your RTU, you have to reposition your robot as well. With extended axis, you have (World 'S' G1) motion type which will keep your TCP in the same point in space while you jog your rail axis, and move group 1 to account for the rail motion.
  • Iprogram
    148
    • November 2, 2023 at 7:14 PM
    Quote from retobor
    ok let me try this setup because i am in the process of setting up IIC and cant get it to work at all! probably because its setup in group 2. Thank you!
Similar Threads
  • Multi Pallet Palletization
    • Harry Hollaway
    • November 15, 2022 at 3:53 AM
    • General Discussion of Industrial Robots Only
  • Maintenance of Kuka robot
    • KovBo
    • June 28, 2022 at 11:18 AM
    • KUKA Robot Forum
  • Fanuc M-710iC maintenance - grease replacement in joints
    • kevster
    • July 30, 2021 at 8:55 AM
    • Fanuc Robot Forum
  • importing / adding and orienting igs components to workcell (Roboguide)
    • zahid990170
    • June 30, 2021 at 4:05 PM
    • Fanuc Robot Forum
  • Mastering kuka robot in a position very different from the indicated by kuka (KR 8 R2100-2 arc HW)
    • ruicfc
    • April 27, 2021 at 8:40 PM
    • KUKA Robot Forum
  • R-30iA 7-8 axis milling or plasma setup
    • javaman
    • October 26, 2020 at 4:26 PM
    • Fanuc Robot Forum
  • Attach Machine (Conveyor) to Rail in Roboguide
    • audijus
    • August 19, 2020 at 4:38 PM
    • Fanuc Robot Forum
  • Fanuc Mastering, Vision, 7th Axis Questions
    • jariuscs
    • December 9, 2019 at 8:53 PM
    • Fanuc Robot Forum
  • Smooth toolpathing
    • Dreamawake
    • November 27, 2019 at 3:53 AM
    • ABB Robot Forum
