Hi guys,
Is there a way to check if any flag bits are ON?
does anyone know of any system variable that can be used to check the above?
Thanks.
Hi guys,
Thanks.
I am quite sure that there is no system variable that indicates this.
You may loop over the flags...
Or maybe it's possible to map 16-bits Group I/Os to Rack 34 (Flags) and check each Group I/O for <> 0 (should maybe speed up the process of cycling through all the flags)?
Thank you very much. This worked.
