I have a Fanuc R-J3iB controller and in the IO list I couldn't find the FLAGS option
please help to find this
Check the following system variables. Set use flg to 1 or true, and set num flg to however many flags you want available.
$MIX_LOGIC.$USE_FLG
$MIX_LOGIC.$NUM_FLG
$MIX_LOGIC.$USE_FLG
$MIX_LOGIC.$NUM_FLG
Sorry but I could not these variables in my TP
is there any other way
please help
Probably is not available on that older controller version.
Instead you could use the internal mem port. Set a block of DO's to rack 0 slot 0. Then you will have DOs that act just like flags.
Instead, you could use the internal mem port. Set a block of DO's to rack 0 slot 0. Then you will have DOs that act just like flags.
can I use group IO to act like as flags
A DO is a boolean just like a flag.
A GO is an integer.
You can configure either DO or GO to rack 0 slot 0.
Flags seems to be a part of mixed logic and is an option on a RJ-3ib controller.
As far as I know it is a free option, but is has to be installed when installing the core software. (it has to be in the orderfile)
I don't know if it is possible to install it afterwards.
But the trick from HawkME is excellent when you only need the flags.
