KRC5 Aut mode
  • GriF
  • August 30, 2023 at 2:08 PM
  • GriF
    I am running the robot in AUT mode, and there is an issue I need to resolve. When the robot is given the start command and it's in operation, if it enters the light barrier, the robot correctly engages its safety protocols and stops. After moving away from the light barrier and pressing the start button again, I want the robot to continue from where it stopped. I attempted to synchronize the $DRIVES_ON signal with the start button signal, but I couldn't manage to make it work. Is there a way to achieve this?
    Thank you very much for your help in advance.
  • kwakisaki August 30, 2023 at 2:46 PM
    Approved the thread.
  • SkyeFire
    1,062
    9,465
    • August 30, 2023 at 5:01 PM
    AUT or EXT? The $DRIVES_ON and $PRO_START signals don't work in AUT mode, as far as I'm aware. They also don't have anything to do with resuming a program after a safety stop.
    If the robot has been safety-stopped, the program pointer should be untouched, so the robot should resume the program where it was interrupted once the drives are on and the program is started.
    HOWEVER, the robot will usually try to return to the physical location where it was stopped first. There is also a path-resume tolerance ($NEARPATHTOL). If the robot is outside that tolerance, it will require a manual BCO by running to the next programmed point in Teach before AUT or EXT can be resumed.
    The system variable $NEAR_POSRET is True when the robot is close enough to resume the interrupted path, and False when not.
  • GriF
    • August 30, 2023 at 5:50 PM
    Quote
    AUT veya EXT? Bildiğim kadarıyla $DRIVES_ON ve $PRO_START çalıştırılıyor AUT modunda çalışmıyor. Ayrıca güvenlik amaçlı bir duraklamanın ardından programın devam ettirilmesiyle hiçbir ilgileri yoktur.
    Evet , SkyeFire. AUT modundan bahsediyordum.
    Quote
    Robot güvenli bir şekilde durdurulduysa programın korunmasına dokunulmamalı, bu sayede açıldığında ve program başlatıldığında robotun yarıda kesildiği yerden programın sürdürülmesi gerekir .
    This is where I need assistance. To reactivate the drives, you need to press the motor on button on the teach pendant again. This way, the program continues from where it stopped. What I want, however, is for the program to resume from where it left off without needing to touch the teach pendant, by activating the drives with the start button.
    Fubini
    285
    1,906
    • August 30, 2023 at 6:00 PM
    Thats not what AUT mode is for. For this there is EXT or only stop the robot without loosing drives when your light curtain is hit. The latter might not be allowed due to safety regulations.
    Fubini
  • SkyeFire
    1,062
    9,465
    • August 30, 2023 at 8:04 PM
    Quote from GriF
    In AUT mode, the only way to start the robot is to use the Start button on the pendant. What button are you using to start the robot?
  • panic mode
    1,300
    13,144
    • August 30, 2023 at 9:03 PM
    Quote from GriF
    not supposed to run into area that is not cleared but - at least the safety works.
    Quote from GriF
    how do you move it away? you must be changing mode to T1 and jogging. Are you aborting program?
    What do you mean by continue from where it stopped? if program was not aborted, and you just jogged away, next time you press Start it will do a BCO to a place where it was on path and continue running same program (or try since this is protected by light barrier)
    Quote from GriF
    You need to acknowledge/clear any errors, enable drives, make sure to change mode back to AUT and then press Start.
    or... don't use AUT mode. add PLC and configure robot to use EXT mode. then on a press of a button (not smartPad), PLC can tell robot to acknowledge messages, enable drives and run.
  • GriF
    • August 31, 2023 at 9:13 PM
    Thank you panic mode  SkyeFire  Fubini
    I tried the configuration with the EXT mode you mentioned. I assigned the input 16 signal to Motion enable. Afterwards, I provided a continuous supply voltage of +24V to the input 16 signal. I assigned the signal that becomes active when I press the start button on input 1 to both Program start and Ext start, and I'm operating in EXT mode. Thank you for your assistance.
Similar Threads
  • KRC5 Micro with Agilus KR6
    • SkyeFire
    • June 17, 2022 at 5:04 PM
    • KUKA Robot Forum
  • KSS00479 - Automatic mode blocked and KSS00249 MOVE_ENABLEconfiguration not allowed
    • GoodFellas41
    • June 23, 2023 at 2:52 PM
    • KUKA Robot Forum
  • AUT modu
