KRC1 under voltage pm1 error
  • najafabadi
  • August 2, 2023 at 7:42 AM
  • najafabadi
    56
    We have a kuka KRC1 that has the error under voltage PM1. Can this error be from software settings?
  • najafabadi
    56
    • August 3, 2023 at 9:28 AM
    Any advice to fix this error?
  • Manuc
    • November 18, 2023 at 9:27 PM
    did you calibrate the axis?
    panic mode
    1,293
    13,122
    • November 19, 2023 at 8:47 AM
    In case of KRC1, there is a lot of stuff inside PM600, everything but KPC (600VDC supply,27VDC supply, servo drives for six axes...)
    undervoltage could be an indication of a wiring problem, hardware fault (such as defective PM600), possibly missing phase or something causing too much of a current draw, even on 27VDC circuit.
  • najafabadi
    56
    • November 26, 2023 at 8:16 AM
    The problem finally solved. First we checked the IGBT which was working properly. And then we checked the feedback circuit and CT, which was the problem, and by repairing it, the problem was solved.
  • Rikkoman
    14
    • February 19, 2024 at 2:47 PM
    Hello najafabadi,
    I am also trying to fix a pm6-600, I was curious about what you meant with feedback circuit and CT. And how do you go about fixing it. CT is current transformer?
    Thanks in advance
Similar Threads
  • Repairing PM6-600 circuits
    • najafabadi
    • July 31, 2023 at 9:06 AM
    • KUKA Robot Forum
  • KRC1 Pm6-600 PM1
