New to robotics and I have been tasked to wire up some solenoids and reed switches on the eoat. I have a CP300L and have my wiring complete. My question is is there a way to test this I/O without a program installed?
adding I/O
CyBot -
May 9, 2023 at 7:47 PM -
95devils
May 9, 2023 at 8:24 PM Approved the thread. -
Welcome to the forum............
Many methods, but the simplest from the teach pendant you can monitor the status of IO, plus turn on/off outputs using the monitoring pages.
** You cannot force inputs, you will need to trigger these using your input devices**
For outputs:
- Use the output monitoring page on the pendant, locate the relevant output signal and turn it on or off.
For inputs:
- Use the input monitoring page on the pendant, trigger your EOAT inputs and check your inputs light up.
Check out the attached clip for those.
