DX200 controller has the option to display IO Names in Job. Can be turned on in Main Menu->Setup->Function Enable->General I/O Name Disp. On Job.
This essentially displays the name assigned to that specific Input or Output in the job like a comment would be shown, to the right of the line the input or output is used on.
Is there a similar setting for Double vars or Position vars? I've been just adding comments above each line when I write my jobs but its tedious to comb through every job to update them if you ever change the name or assignment of a Pvar for example.
Thanks in advance!
