Hello everyone, we are currently doing image backups on the R30ib controller, using USB we went through menu>File, Set the device, and made a DIR. One robot is getting stuck at the same line (FROM31, 32/65) on multiple flash drives. any idea as to why we cant get this backup to complete? any help would be appreciated.
R30iB Image Backup
Bwille -
April 17, 2023 at 6:32 PM -
kwakisaki
April 17, 2023 at 6:44 PM Approved the thread. -
Did you try doing the image backup from the teach pendant USB and controller USB?
yes i did try both the door and the pendant USB
I've actually seen this issue before and it's usually that block of the FROM is corrupted. If you do eventually get the image be sure to check the img file size. If it's not the same as others it's corrupted.
