Problem with robot backup
  • dahonora
  • February 22, 2021 at 4:14 PM
  • dahonora
    7
    Hi There!
    We had been struggling for some time now to get an image backup from an R30iB controller. The controller is commanding a delta robot M-3iA/6s. We are using the controller UD1 port to get the image with a USB flash drive. We had tried several different USB flash drives, with bigger or smaller capacity, 'recommended' by Fanuc, etc. Specifically, we had tried:
    - To do a backup from the controlled start (F1 + F5)
    - To do a backup from the FILE Menu in cold start
    - With a USB drive formatted in the robot
    - With a USB drive with the size of 2Gb, 4Gb or bigger (included some Sandisk Cruzer Blade)
    What we are seeing, is that the robot generates all the FROMXX.IMG, but gets stuck in the SRAM00.IMG file. It doesn't finish after waiting for more than 1 hour, and we are forced to turn off the robot. After taking out the USB from the robot, the robot starts correctly, but in the USB there are the FROMXX.IMG files, but not the SRAMXX.IMG files (Please, see the attached image for reference)
    Do any of you guys have experience dealing with a similar problem? Thanks!
    Images
      • 93.33 kB
      • 576 × 1,280
      • 8
  • Fabian Munoz
    133
    Articles
    1,517
    • February 22, 2021 at 4:50 PM
    Sorry, I've been there, last file and it fails
    Try different USB Different brand and size
    Try UT1. UD1 is, believe or not more reliable, but in your case try UT1
    Retired but still helping
  • dahonora
    7
    • February 22, 2021 at 5:09 PM
    Quote from Fabian Munoz
    Did you actually solve it? I think we had tried every single combination, with different USB flash drives. But if you solved it just by trying other options, we might have some hope I guess.
    Could it be some kind of problem in the SRAM memory?
    We have 14 of the same robots and no problem with them. Only with this specific robot, we are facing this backup problem.
    Edited once, last by dahonora (February 22, 2021 at 5:17 PM).
  • Fabian Munoz
    133
    Articles
    1,517
    • February 22, 2021 at 5:19 PM
    Yes, eventually worked. It's been a long time and I do not remember the magic involved.
    Like you said I also tried every single combo, maybe the solution was combinations of combinations
    Did you try formatting the USB using Fanuc format ?
    Can you do any other backup ? Don't laugh, but maybe the operating system is stack somewhere and another backup will wake it up.
  • jpsantos96
    15
    • February 22, 2021 at 5:20 PM
    Already tried MC: card?
  • dahonora
    7
    • February 22, 2021 at 5:46 PM
    Quote from jpsantos96
    No, we haven't tried with a Memory Card (I suppose we are referring to the PCMCIA). Do you think, that is worth trying?
  • jpsantos96
    15
    • February 22, 2021 at 5:47 PM
    Quote from dahonora
    Yes, the PCMCIA. Yup, sometimes it solves my issues, if you have one laying around, be sure to give it a try!
  • dahonora
    7
    • February 22, 2021 at 9:20 PM
    Yes, we tried formating the USB using the Fanuc format.
    We had been doing 'All of Above' backups without problems.
    As for the other suggestion about the PCMCIA, we don't have any around, but I will be sure to get one and give it a try.
  • dahonora
    7
    • April 22, 2021 at 6:03 PM
    Coming back with this issue. We got a new MC of 256Mb and gave it a try, but the problem persists.
  • alive15
    15
    160
    • April 22, 2021 at 7:16 PM
    What's USB size? I can never get anything more than 2 GB to work, so maybe try smaller memory on flash drive. I'm very surprised the MC card didn't work. Did you try to get answers from Fanuc directly? They would definitely point you in the right direction.
  • Skooter
    167
    2,001
    • April 23, 2021 at 12:57 AM
    • #11
    Format the MC in the robot and try again.
    For the UD1 USB, try swapping the USB & cable from the SOP-to-CPU with one from a robot that works to see if the problem moves.
    For UT1 USB, swap pendant and cable together with one that works and try again.
    If you still have issues with the SRAM image and have a good AoA backup, you may want to consider an INIT Start and then load in the backup.
    As alive15 said, calling Fanuc may be good place to start before spending more time on this.
  • neighbour1
    44
    405
    • April 26, 2021 at 9:50 AM
    • #12
    Skooter, alive15, dahonora, jpsantos96 - as far as I know, in R-30iB and later there's no possibility to make z backup using MC. I suppose they stopped supporting it. It was working until R-30iA.
    But when I have a chance to have R-30iB in my hands I'll make a try myself and let you know.
  • pdl
    266
    1,504
    • April 26, 2021 at 7:37 PM
    • #13
    PCMCIA adapters with Compact Flash cards still work and I prefer to use them for system software installation and auto updates. USB is still hit and miss, MC has always worked for me.
  • Skooter
    167
    2,001
    • April 28, 2021 at 1:07 AM
    • #14
    Quote from neighbour1
    I must admit that you made me go look to verify the R-30iB Main Board had the PCMCIA port. Like pdl says, it seem more reliable and it works when the USB ports might not be the best option due to foreign material in them.
  • HawkME
    567
    10
    3,268
    • April 28, 2021 at 2:04 AM
    • #15
    I've never had an issue using USB drives. Maybe I'm just lucky.
  • pdl
    266
    1,504
    • April 28, 2021 at 4:35 AM
    • #16
    I have had multiple issues when installing system software via UD1: especially with the new green and black USB drives. Off the top of my head, I believe that they are Transcend brand.
    I always run the apverify batch file, and they will always pass, but they usually will hang during the second phase of the software install at "¥control1.com loading".
    I have never tried to do an ethernet install, and I don't think I have ever found any documentation on doing one. I am guessing that it's reserved for Fanuc and maybe the automotive guys.
  • Nation
    Typical Robot Error
    522
    1,900
    • April 28, 2021 at 4:48 AM
    • #17
    Quote from pdl
    I had a similar issue during software install, so I called Fanuc about it, and, I kid you not, the tech told me to jiggle the stick. To my amazement, it worked.
  • neighbour1
    44
    405
    • April 28, 2021 at 7:22 AM
    • #18
    Quote from Skooter
    Skooter I haven't said it's not there, it is, sure. But I heard somewhere they stopped supporting doing backup since R-30iB. Maybe I missed something. Have you tried to do it with success?
  • pdl
    266
    1,504
    • April 28, 2021 at 2:41 PM
    • #19
    I've used it on a R30iB+ v9.3, so I'm pretty sure it's still supported.:grinning_face_with_smiling_eyes:
  • neighbour1
    44
    405
    • April 29, 2021 at 4:47 PM
    • #20
    Quote from pdl
    Super, it's always good to know! :smiling_face:
Similar Threads
  • Zeroing data lost
    • arun_AR
    • June 27, 2020 at 10:30 AM
    • Kawasaki Robot Forum
  • robot programmer job
    • Serek
    • April 16, 2020 at 11:38 AM
    • General Discussion of Industrial Robots Only
  • Profinet loosing the connection with Robot during backup from workvisual
    • tarun89engg
    • August 3, 2018 at 10:43 AM
    • KUKA Robot Forum
  • r30ib
