Hi everyone,
Any one knows if its possible to use Rockwell Piont I/O (1734- AENTR ou ANTE) as remote IO from a kuka controller (the same way as beckhoff is)?
I have a KRC5 (KSS 8.7.4) using WoV 6.26 and did not have success.
I tried to import the newest .EDS files downloaded from rockwell site and did not work. I used the EDSWizard (found on C:\Program Files (x86)\KUKA\WorkVisual 6.0\DTMs\EthetNetIP ) and received an error: "Error during analysis of file 0001002300010100.eds. This EDS does not have an EtherNet/IP device class or a modular section. This means that the EDS cannot be added to the device library."
Then, I tryed some older version of the EDS files and the files where imported and I added them to my DTM (several versions).
But when I tried to add the divece to my Ethernet/IP bus I have an error: "Erro no DTM 1734-AENTR EtherNet/IP Adapter Revision 3.2: Device type not supported"
Anyone knows if its possible this communication?
Whitch EDS should I use?
After this adapter insertion, the configuration of the IN/OUT cards are done the same way as beckhoff? Which EDS I use for then ( 1734-IB8 and OB8)?
Thanks in advance,
Marcelo Rebouças
