Up until 2 days ago the dual cell had no known issues with memory or storage. Went to modify a job and error shows, 2280 Job memory full(2) I believe that’s exactly how it was stated I don’t have the teach pendant in hand at this moment. It seems it’s only on certain jobs, I just modified one in same robot a few minutes ago. Even deleted multiple old jobs off Select job page and trash bin. Any suggestions for other ways to free up space? Or fixes for this error? Thank you, £¢
Job Memory Full Motoman DX100
Tcgatorfan -
February 11, 2023 at 2:58 AM -
This area is calculated from the memory, number of steps, and number of lines.
Unnecessary JOBs need to be deleted.
If you are using the play-in-progress JOB editing function, etc., you should delete those logs as well.
If that does not solve the problem, you can try to initialize the JOB after making a backup.
Is your trash job list enabled? We had one which was and had not been cleared out. It became full and it became a nightmare to clear out. That was DX200, but ought to be similar.
So I went through and deleted all the old programs but was still showing the same error after maybe 1 modification it would throw same error again. The issue was fixed by someone else but they don’t work on the same shift as me so I have no idea how they fixed it. Every now and then it will pop back up and I just have to kinda roll with it. ClassyBanana: how do you tell wether or not the Play in progress job editing is being used?
If a JOB is registered to be edited during playback mode, you will see it listed under the play in progress editing menu.
You need to boot in maintenance mode and format the job area (known as the job table). It's like doing a low level format of a hard drive in your computer.
