What is mechanical role of these parts on A2 gearbox? They are three on 120 deg. mounted and it seems that assure sealing ring on gearbox.
They are used to adjust also its position depending on use age?
I don't recall ever seeing that before. They might have been added aftermarket by someone who used them for... I dunno. To trip limit switches, maybe?
The axis hard stops were mounted in a similar fashion, but much larger and spanning 4-6 bolts (which had to be replaced with longer bolts of a specific length). That little thing is definitely not a hard stop of any kind.
don't think i've seen it either. looks like seal retention clamp. maybe an aftermarket product or part of a retrofit kit.
