Hello all,
I'm new to Fanucs....
Is it possible to always cold start when turning off and on the controller? Without having to explicitly select "cold" from FNCT menus
We are using a CRX with R-30iB mini plus
many thx
Hello all,
many thx
I'm not 100% certain on the CRX models, but cold start is default behavior for all regular yellow robots. They only do a hot start if you have purposely enabled that in the System Config menu. CRX may be different.
I asked a Fanuc welder a week ago, he was saying the cycle start is the cold start.
many thanks!
You can check and change this by going to Menu>--Next-->System>Config.
The first option itself is for Hot Start.
"Cycle power", not cycle start. By default that will be true unless you enable hot start.
