NX 100
  • Ro Bo Rye
  • September 28, 2022 at 3:53 PM
  • Ro Bo Rye
    20
    We have an NX 100 ES 165 that has a damaged U axis encoder cable connection. Cable is fine, broken prong on encoder UTSAE-B17CL connector. We usually just replace the entire motor with encoder attached. If we were to simply swap out U axis encoder with another one from an identical robot, is this recommended? Both full motor with encoder swap vs just encoder swap involve Absolute data recovery so I am thinking just encoder may be quicker. Not sure how an encoder used on a different motor might react. Thoughts??
    Cheers! :top:
  • 95devils
    235
    8
    1,951
    • September 28, 2022 at 8:02 PM
    There is not really a recommendation for this. Majority of motors the encoder can not be swapped out independently. The robot you mention has the bigger motors that could have the encoder swapped.
    It's a damn if you do, damned if you don't. There is a plug bolt that gets removed. Inside is a coupling that needs to be jammed up with a 2.5mm allen wrench. I have had times where the bolt inside the plug is too tight to remove and bend the allen wrench. On the coupling on the encoder side is a pin. That pin has to align into a hole on the encoder. There isn't a good way to really know if they are aligned. You will know when you turn on servo power and the U-axis starts to fall and the controller slams on the brakes.
Similar Threads
  • Interrupt Example
    • SkyeFire
    • March 18, 2021 at 8:25 PM
    • Manuals, Software and Tools for KUKA Robots
  • array/grid-wise measurement with kuka robot
    • El_Mo
    • June 25, 2022 at 3:43 PM
    • KUKA Robot Forum
  • program explanation
    • Abhi123
    • January 20, 2022 at 1:27 PM
    • KUKA Robot Forum
  • Adjusting TOOL_DATA
    • martenH
    • October 28, 2021 at 1:19 PM
    • KUKA Robot Forum
  • Kuka inline forms
    • NiNok
    • March 27, 2019 at 10:15 AM
    • KUKA Robot Forum
  • Code Review for KRC2 2005ed and Other Questions
    • Nation
    • July 17, 2020 at 10:59 PM
    • KUKA Robot Forum
  • ABB robot Studio issue with axis rotation - why cannot work??
    • Tatyana Uzunova
    • October 6, 2020 at 7:01 AM
    • ABB Robot Forum
  • My new used kuka KR200L170 comp
    • cientista
    • March 24, 2018 at 2:00 PM
    • KUKA Robot Forum
  • NX 100 U axis Encoder swap
