Speed drops to 10% when gates open
  • I need to stop the speed from dropping to 10% when the safety gates are open. This is causing operators to have to adjust speed after the gates are closed and I need to prevent this. I want to take away the need for operators to adjust speed all together. How can I do this? Or adjust speed the robot goes to after safety circuit closes ?
  • You can try setting the Override Select function.
    Menu > Setup > Ovrd Select
    You need two DI's for the speed control.
    DI1=ON AND DI2=ON 100%
    DI1=ON AND DI2=OFF 50%
    DI1=OFF AND DI2=ON 25%
    DI1=OFF AND DI2=OFF 10%
    Another solution is background logic
    : IF (SO[7:TP enabled = ON) THEN ;
    : OVERRIDE=100% ;
    : ENDIF ;
  • It won't let me use the If statement in BG logic. It's saying invalid operator
