Custom HMI, START button
  • Hi!
    I'm creating a custom HMI screen to the TP. I have a dropdown list to select from the TP programs available. This sets the currently active program to the selected.
    Then I can run the program from the controllers CYCLE START button.
    Instead I want to control the start from the HMI screen, using KAREL, without OUP mapping. So I want the CYCLE START button on the HMI screen.
    Could the CONTINUE karel action work? This gives me a lot of errors at compilation.
    Is there any way in KAREL to just start the currently active program?
  • I found the solution...
    I have to use this KARAEL command:
    RUN_TASK( progName, 0, FALSE, FALSE, 1, STATUS )
    Hi, i am at the end of a robot integration. I have completed all of the points and am now at a stage where I want to bring all the controls away from the TP and controller and onto the HMI. Do you know where I could look for guidance? I have never done this. The only HMI programming i Have done is with PLC. I will be using a Allen Bradley for current project. I need to select recipes from HMI, cycle start, hold, terminate pallet.
