Pausing Program in Auto Mode
  • Searchligt_1
  • June 9, 2022 at 8:14 PM
  • Searchligt_1
    7
    Hello everyone,
    I am trying to use the pause command to halt the robot in the middle of its program so that the operator can interact with the part. Once they are done, they can reset the robot and have it resume its path. I have tried inserting the pause command into the main program; the robot stops and will not start back up. There is a sub-program that is called in the main program with the pause command, and it behaves correctly. The robot will stop, the operator changes tools, they reset the robot and the robot begins running again. I don't know why it works in the sub program, and not in the main.
  • HawkME
    567
    10
    3,268
    • June 10, 2022 at 12:03 AM
    How are you resuming it? UOP? Can give more details?
  • Searchligt_1
    7
    • June 10, 2022 at 6:08 PM
    UOP is being used. The operator has to turn a key, has 2 resets, then swipes their finger on a sensor to start the robot.
  • wag_FFU
    85
    • June 12, 2022 at 3:46 PM
    Hi, I´m trying to perform the same task, but I´encontering a very strange problem.
    I´m Working with a Paint Robot, than use the Paint tool, so i´m not using the UOP because Paint tool use some build-in input to start and resume the JOB.
    My problem is:
    if the robot receive an HOLD command in the middle of a movement it can restart the program successfull and finish the Task.
    If the HOLD command come when the robot is waiting for something (wait instruction) It can not resume the Job proprerly.
    What is strange is that the robot stop correctly, and turn off "the JOB active output" and turn on the" wait for plc action output"and, in the first case (Hold during a movement) receive the "continue" input, it turn off the" wait for plc action output", turn on "JOB active output" and restart the job. in the second case it restart the job without turning off the " wait for plc action output" and when the Job is finisched it doesn´t turn off "JOB active output".
    Probably it depends from the Paint Tool nature that it´s a karel programs running in the controller.
    someone had the same problem?
  • wag_FFU
    85
    • June 13, 2022 at 10:04 AM
    Only to now , is there a Variable or somethings to now When the robot is performing a movement? Off course I can read the position variable and make a bg_Logic than turn ON a bit when the robot is moving, but I was looking for something elegant...
  • DS186
    198
    1,048
    • June 13, 2022 at 10:12 AM
    You can use $MOR_GRP[1].$ROB_MOVE in a BG logic task to check if the robot is moving, e.g. DO[n]=($MOR_GRP[1].$ROB_MOVE).
  • wag_FFU
    85
    • June 13, 2022 at 11:03 AM
    Yes It Work, tnks
Similar Threads
  • IGNORE PAUSE in header and NOPAUSE translator directive
    • lomaxe
    • December 4, 2018 at 9:23 AM
    • Fanuc Robot Forum
