Does someone know how to offset the points from a part of the program with a defined value, i need to move a welding seam with a few cm down or up
Welding
Chardafon -
June 6, 2022 at 9:52 AM -
You could use Tool_Offset, PR[x] command to the points need to be shifted, before preparing your offset in PR[x].
Thank you very much that was how I decided to do it too
When I was moving my model,that was working on one robot to another , the welding seams position was shifted so I did a program shift with the correct offset. Problem is that the points were automatically renumbered wich created problem with the Multipasses. Is there more optimal way to do it?
User frames and tool frames.
