Pairing robots with old CNC machines
  • seskotristan
  • May 20, 2022 at 10:39 AM
  • seskotristan
    36
    Hello guys,
    at our company we are about to automate our shaft/gear production but we are curently using older CNC machines (the machines are in good shape), they were made betwen 1975 and 1995 and I was wondering if any1 has any "tips&tricks" for automation with older types of machines or things I should be carefull about.
    Thanks for the help in advance!
    Regards
  • Go to Best Answer
    SkyeFire
    1,052
    9,429
    • May 20, 2022 at 1:52 PM
    Well, the first question is, how are the robots and CNCs going to interact? Followed by, how will the robots and CNCs communicate?
    A robot reaching into a CNC without some sort of interlock is a good setup for a very expensive collision. But some old CNCs are so "standalone" that they provide nothing, or at best very little, in terms of I/O interfacing to other pieces of automation. I've literally seen people attach small pneumatic cylinders to their CNC control panel to push different buttons, and attach photo-diode sensors to different indicator lights, because the CNC controller provided no means of exchanging signals other equipment, only with human operators.
    Just for starters, if your CNC has a door, you'll want a very solid way of letting the robot know that the door is fully open before reaching in. If the robot is going to grab the door and open/close it, you'll need reliable sensors for the "closed" position as well.
    If the robot is loading stock, you can run into issues with stock size variance. Robot's don't usually have touch-off probing, so rely on whatever they're working with to be the same size every time. Clamping stock might be an issue if you have a manual vise -- trying to teach a robot to turn a vise handle is liable to be... interesting. And not terribly consistent in applied torque.
  • seskotristan
    36
    • May 20, 2022 at 2:34 PM
    Thanks for the detailed answer or explanation! Our CNC's have some I/O's but they are very limited I would say.. Maybe an input for cycle start and output for cycle end, but as you said the doors would deffinetly need some upgrades (limit switches). Chucks are hyduralic so I would just use a relay instead of a pedal. We will try to avoid turning stocks, but if the stocks vary only in lenght (turning) it shouldn't be a problem as long as we use some kind of pressure piece on our gripper.
    When you mentioned an interlock you meant a chuck interlock?
    Regards
  • kwakisaki
    694
    4,770
    • May 20, 2022 at 3:30 PM
    I would also look at the safety circuit side too and the retrofitting of robot systems, as most operate off dual channel now, with circuit analysis technology and therefore an assessment in line with your regional, national and machinery directives will be required to ensure the appropriate standards are followed relating to retrofitting to existing systems.
    I know some robot systems have options for single channel, but wouldn't like to speculate whether they would be permissible as a retrofit solution or if some conversion from single to dual channel is required to upgrade the older to the newer dual channel conditioning, this you would have to research further.
    Not sure if I'm off the mark here, but you mentioned 1975....
    SkyeFire
    1,052
    9,429
    • May 20, 2022 at 3:31 PM
    Quote from seskotristan
    More like, a set of interlocks. The door would be one -- you need positive information on whether it's open, closed, or "unkown". Likewise, you need some sort of interlock to ensure that a programming error can't start the CNC while the robot is inside its working volume, or tell the robot to reach into the CNC while the CNC is still moving. Interlocking the chuck would depend on whether the robot has to be holding the stock while the chuck closes on it, or needs to grab the finished work piece before the chuck opens.
  • seskotristan
    36
    • May 23, 2022 at 7:36 AM
    Thanks guys! 1 more question.. What would you recommend if the machine doesn't support I/O that you can use in its ladder?
    Regards
    SkyeFire
    1,052
    9,429
    • May 23, 2022 at 2:34 PM
    Ladder? Wouldn't a CNC machine normally control I/O through G-Code?
    If you can't control interface signals through I/O, then it gets more complex. Say, for example, the CNC has an automatic door that it can open/close from inside a G-Code program. You could add sensors to the door such that the robot could detect the door opening, and trigger the robot's unload/reload program based on that. Probably you would want to wire an extra relay in series with the powered door, controlled by the robot, so that the robot could block the CNC from moving the door as long as the robot was not clear.
    It all depends on what signals or hardware you have how much access to.
  • hermann
    407
    2,612
    • May 23, 2022 at 5:24 PM
    • Best Answer
    Quote from SkyeFire
    All CNC machines I know have a PLC running in the background doing things like ranking I/O, making plausibility checks for the I/O, converting M-codes to the specific I/O, handling options and so on.
    The G-code can't handle I/Os direct, they all are ranked through a PLC that does some logic that's neccessary for the M functions controlling the I/O.
    SkyeFire
    1,052
    9,429
    • May 24, 2022 at 2:35 PM
    Quote from hermann
    Well, I learned something! :dance:
    My CNC experience is pretty limited, but the ones I've worked with had just a small number of relays that were controlled directly by G-Code, with no background ladder-logic processors.
  • MOM
    175
    7
    1,424
    • May 24, 2022 at 7:14 PM
    First thing I would check for this type of cnc machine:
    - List of M-Codes
    - Circuit diagram
    Normally the outputs are controlled by cnc code (M-commands) directly; maybe start and stop as well (depends of cnc machine)
    SkyeFire
    1,052
    9,429
    • May 24, 2022 at 8:56 PM
    • #11
    Quote from MOM
    M51 and M61, and so on, on Haas CNCs, IIRC.
  • Robo-Warrior
    • June 3, 2022 at 4:57 PM
    • #12
    I've done this once before and from what I can remember the Mfin relays were one of the main communication points, its also depends one how old your cnc is, and what your using the robot for
  • milling
  • cnc
  • lathe
