what does it do?
there is no mention of it on Xpert:
what does it do?
KUKA.Applications KRC 1.2 is an option from KUKA Belgium.
Maybe not compatible with Option KUKA.CPC.
You are absolutely right.
Kuka.CPC
- Features „ Executable files are checked before running ...
what does it do?
For example, KUKA.Applications must be previousely installed for subsequent KUKA.CamRob installation!
i see. On KSS 8.2 and 8.3 CamRob only needs UserTech. Looks like on KSS5x it needed more than that...
I would ask, what are the consequences for the controller proper working if KUKA.CPC is uninstalled prior to installation of other software and the opposite, if KUKA.CPC is installed again when the other software is previously uninstalled ?
KUKA.CPC is an option to prevent unauthorized software installations.
Each option requires a certificate issued by KUKA.
How to install this certificate, please refer to the KUKA.CPC documentation.
KUKA.CPC has no influence on your KRL programs.
This option is mainly used on robots in the automotive industry.
Existing certificates should be under C:\PROGRAM FILES\KUKA.CPC\APPCACHE. File extension .appcert.
Before uninstalling the option, please make an image of the hard disk.
Exactly, the robot came from automotive industry and the purpose of the KUKA.CPC option package is as it was clearly described.
The main problem is that there is no way to uninstall KUKA.CPC ! ("It's not allowed to de-install this software !").
