Good day. Will Motor SGMDH-32A2A-YR33 work on NX100. What will i need.
Thank you
Thank you
Looks like that motor is a Sigma II motor. NX100 uses a Sigma V motor.
There are work arounds for the brake section (90 V vs 24 V). The difficult part is finding a converter/amplifier section to control this ancient motor.
Yes it is ancient motor. I have done research on this motor. See attachment that I have found it is possible but also contact Yaskawa and waiting for answer. Also what i would like to know is to get cables for motor and encoder and internal harness kit for it to work.
Yes this motor will work on an NX100, but you need to know special parameters to set, and as 95devils said, you will need to figure a way to get 90 volts DC to the brake when servo power is on.
In the past, I've seen 90V adapters by Warner used in brake circuits for external axes in real old cells made by Genesis Systems. MRC & Fanuc R-J/R-J2 running off the 200/220VAC if I remember correctly.
