I am looking for a way to monitor certain arc faults then use a singular output to notify the PLC, to prevent excessive resetting. Is there a variable for active errors that I could write into a BG logic program or something I am missing in the weld equipment setup? I looked into the error output option, it is excessive for what I'm after.
Error output to PLC without error output option
C_hiney -
March 28, 2022 at 12:37 PM -
- Go to Best Answer
What about condition program?
Condition monitor or Bg logic would suit this well but I need a way to identify when an arc start fail or lost detect occurs. Needing a way to identify specific errors outside of error output so when said error occurs i can trigger an output. Variable or a setting i have overlooked? Outside of karel because i have zero experience with it.
Are you using EthernetIP by chance? If so it is very easy to get the error codes to output to the PLC with message instruction.
Do you have the remote iPendant option?
There's the RSS Alarm list function. You can reach alarm through EthernetIP, in HTML form.
- Best Answer
Look into the manual, section with alarms - each of them has a specific ID and a number, such as:
- ARC alarms => ID = 53
- ARC-013 PAUSE.L Arc start failed => alarm number is 013
which meens: the ARC start failed error number is 53013.
For the rest use the same method
Then use condition program:
WHEN ERR_NUM = 53013 ....
No need to have special function and options, which also work fine
