Hello there I'm currently using a M-20ia series robot and I'm stuck with this code Srvo-348 dcs mcc off alarm 01 and i called some people and they told me it was an E-stop Unit but we already checked them all and i cant find anything wrong with them. Any suggestions on what can i do next?
- Ivan8793
- Thread is Unresolved
There is a picture of the code I get
Lemster68
Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum. -
This error indicates a problem with switching off the motor control contactor. I would suggest to check all devices/signals connected to the E-Stop board. It could also be a blown fuse on the E-Stop board or a defective E-Stop board itself.
Did you switch the power of the controller off and on again? To reset this error, a power cycle of the controller is required.
Yes we did all of that. We check all fuses and everything and they all seem ok. So maybe we need to replace the E-Stop Board
Try checking the contactors behind the estop board. We had an issue with one of our machines and the contactors were sticking.
Will do, thanks for the tip
I have run into this before, and as Boyd said, it was the contactors behind the E-Stop board. They are part of the "E-Stop Unit".
They are common off the shelf Schneider Electric contactors.
The E-Stop board can be removed by unclipping the white plastic tabs around the perimeter of the board.
Use a meter to verify that the NO and NC contacts are in the correct state. When I encountered the problem, one contact was sticky.
The E-Stop unit was still under warranty, so I had Fanuc replace it for free. But, if it was out of warranty, I would not have hesitated to buy the contactor by itself.
Yeah we just replaced the E unit and now robot is now running. Thanks for all the tips guys. They were very helpful to find the problem
