IBS1 Hardware Error
  • panic mode
  • January 23, 2022 at 11:47 PM
  • panic mode
    1,267
    13,033
    hardware defect is reported on powerup indicating problem on interbus, most likely DSE board. DSE uses Interbus is used to communicate with RDC and drives. only have Basic Xpert so cannot help with message. last document that listed messages only went to 6500 or so.
    flashing green light on DSE is normal.
    fast flashing of two red LEDs on KPS is normal. when there is an EStop they show different state and stop flashing.
    so how many robots you got there? any chance to swap some hardware?
    you can also try DSE-RDW tool to look for anomalies.
  • Gocea
    156
    • January 24, 2022 at 12:04 AM
    Quote from panic mode
    Only one robot is present and none nearby. So, there is no chance to exchange the Mfc/Dse in my case.
    Batteries are below 22v, probably (previous message). I've ordered new battery pack, expecting to receive it these days.
    When I connect Wago controller to the Mfc card, the Kss even doesn't boot up.
    May I ask, does the:
    -empty batteries
    -blown fuse or
    -iosys.ini
    may influence this issue?
  • panic mode
    1,267
    13,033
    • January 24, 2022 at 12:36 AM
    Wago controller?
  • Gocea
    156
    • January 24, 2022 at 12:46 AM
    Wago controller?
    WAGO DeviceNet 750-306.
    Images
      • 107.85 kB
      • 910 × 1,200
      • 7
  • panic mode
    1,267
    13,033
    • January 24, 2022 at 12:54 AM
    that is DeviceNet coupler (slave, not a controller). MFC is controller.
    wrong connections can do many things, including blowing fuses.
  • Gocea
    156
    • January 24, 2022 at 11:44 PM
    I think the problem is that I have Windows XPe installation performed on Pc instead on Krc, that means installation on different motherboard. I'm going to reinstall the Windows and Kuka system software at the Krc controller.
    If you don't mind, I need clear answer of one question. During Windows installation, which option has to be choosen 0, 1 or 2, keepinng in mind that Mfc3 card is present at Krc ?
    Images
      • 270.87 kB
      • 1,080 × 718
      • 6
  • panic mode
    1,267
    13,033
    • January 25, 2022 at 1:33 AM
    did you consider looking at your MFC? does any of the chips seem to be an Ethernet controller?
    MFC2 had ISA interface and onboard Ethernet port. Note Ethernet magnetics next to it:
    MFC3 is PCI board and it does not seem to have that:
  • Gocea
    156
    • January 25, 2022 at 12:21 PM
    It's MFC3 card, so if the network driver installation in this case refere to the Ethernet controller, than option 0=Install no network driver has to be selected, am I right ?
    Images
      • 270.87 kB
      • 1,080 × 718
      • 2
