Position Variable - Pulse or XYX ?
  • FATTY-J
  • August 29, 2021 at 1:47 AM
  • FATTY-J
    What are the main differences, pros & cons of using PULSE or XYZ position type? I've read that with XYZ you need to specify types such as FLIP/NO.FlIP, which seems more complicated than using PULSE type. When and why would you use XYZ instead of PULSE? Thank you.
  • Go to Best Answer
  • TSGIR
    81
    715
    • August 29, 2021 at 5:51 AM
    The PULSE value are feedback from servo motor, when the servo turn, it give you value in PULSE. If you want to use PULSE you must to know how many PULSE is for each turn. It is very hard to understand it therefore it is better to use ROBOT (X,Y,Z). In this Coord, you must set six value for robot and it is understandable.
    You don't need to set the Flip/Noflip, only you move robot and teach in this mode. For teach, press MODIFY+ENTER.
    95devils
    235
    8
    1,951
    • August 29, 2021 at 3:52 PM
    • Best Answer
    Pulse is an absolute position. The arm orientation will be guaranteed. Tool data doesn’t affect the position.
    XYZ is a mathematical position. The arm orientation is not guaranteed. Changing tool data will change the position/orientation or both. XYZ is move the tool to some distance and orientation from something. TCP to the origin of the robot or tcp to the origin of a user frame, etc.
    XYZ position variables can be used for temporary or permanent shifting, IMOVs, or move to this position as in calculated moves.
  • FATTY-J
    • August 29, 2021 at 11:23 PM
    Thanks guys. It makes more sense now.
  • WattUp
    7
    96
    • August 31, 2021 at 3:04 PM
    Quote from 95devils
    Just want to reiterate this point. We had a machine that was taught by the supplier, Every position was a PVAR in XYZ.
    Everything standard worked well, but if an abnormal condition happened, and the maintenance team had to home the robot, they would get the B Axis 180deg out.
    Everything looked normal and it would run, but our final place position was .5mm off and that was visible in the final part.
    Reteaching to PVAR and the issue was gone forever.
Similar Threads
  • $PX011
    • Dawid Firlej
    • May 24, 2021 at 1:31 PM
    • Yaskawa Motoman Robot Forum
  • Motoman MRC alarm 5750 undefined position variable
    • Czirjak Cristian
    • February 16, 2019 at 4:45 PM
  • Motoman MRC istruction inserting without position variable (P00X)
    • Czirjak Cristian
    • February 22, 2019 at 11:59 AM
  • how to displaying position variable yaskawa on inform language
    • vinicius azevedo
    • May 12, 2021 at 7:40 PM
  • Comment utiliser les repères utilisateur sur Motosim
    • Basteak
    • August 6, 2020 at 12:13 PM
  • Unwinding the T axis
    • Sergei Troizky
    • June 13, 2019 at 4:53 PM
  • fix after a major wreck
    • cameronsjunk15
    • September 11, 2018 at 7:59 PM
  • DX-2000 Convert from Cart. to Pulse Coord
    • B0arder606
    • August 23, 2017 at 3:35 PM
