Is there any way to disable the axis 5 and 6?
Disabling axis 5 and 6
Ninogstsax -
June 28, 2021 at 8:04 PM -
Think that's not possible. What do you want to do with a robot that has those four axis? The robot can't make any linear movement, only silly combinations of arcs.
$SCR_GRP[1].$AXISORDER
Set the axis you want to disable =0. Requires a power cycle. Good luck.
bencor21 is right, it will work.
You can also set axis limits upper and lower to the same value, then cycle power and the axis won't move
