I have a fanuc Robot 100 that is stuck on controlled start. The person left it like this. So. How do I get passed this to. Getthe robot functional it is an rj3
  • ktmark
  • June 25, 2021 at 4:20 PM
  • ktmark
    8
    135
    I have a fanuc Robot 100 that is stuck on controlled start. The person left it like this. So. How do I get passed this to. Get the robot functional it is an rj3
    •  EDIT THREAD
    •  REPLY
    •  CREATE THREAD
    Edited once, last by ktmark: did not do it right (June 25, 2021 at 4:42 PM).
  • Boyd
    22
    • June 25, 2021 at 6:45 PM
    Did you try to use the Function button and cold start it?
  • ktmark
    8
    135
    • June 25, 2021 at 6:53 PM
    •  EDIT THREAD
    •  REPLY
    •  CREATE THREAD
  • ktmark
    8
    135
    • June 25, 2021 at 7:31 PM
    NO I HAVEN'T YET HOW do you do that
  • Boyd
    22
    • June 25, 2021 at 7:45 PM
    Find the FCTN key on the top right side of pendant and when your press it, a menu should pop up and have an option for START (COLD)
  • ktmark
    8
    135
    • June 25, 2021 at 8:07 PM
    T
  • ktmark
    8
    135
    • June 25, 2021 at 8:21 PM
    WILL THAT HURT ANYTHING I DID THAT BUT GAVE A ME A WIERD MESSAGE
  • ktmark
    8
    135
    • June 25, 2021 at 9:28 PM
    what is the servo-62 bzal. Mean here is what it looks like after I did what you said
    Images
      • 254.07 kB
      • 1,200 × 1,600
      • 7
  • HawkME
    568
    3,268
    • June 25, 2021 at 9:49 PM
    It means your encoder batteries are dead.
    Bzal = battery zero alarm
    Now you must replace batteries and remaster the robot.
  • ktmark
    8
    135
    • June 26, 2021 at 3:23 AM
    well. I changed all the batteries two weeks ago. I do have a message to take it safe home I might have to do a mast/cal will that remove the alarm ?
  • HawkME
    568
    3,268
    • June 26, 2021 at 3:49 AM
    • #11
    Make sure you did it right. Then reset pca and remaster.
  • ktmark
    8
    135
    • June 26, 2021 at 4:17 PM
    • #12
    okay thanks will work on it Monday morning thanks again..
  • Skooter
    169
    2,026
    • June 26, 2021 at 8:43 PM
    • #13
    Quote from ktmark
    If you changed the batteries with the controller power off, that could be the cause of the BZAL if it alarmed on all 6 axes. Always change Fanuc robot batteries with the power on. If the BZAL is only on 1 axis, then there may be another cause such as intermittent wire, bad Pulsecoder, someone unplugged cable to the Pulsecoder, etc.
    If you search the forum for "BZAL", you will find many examples on how to reset the alarm, mastering, and troubleshooting the alarm.
  • ktmark
    8
    135
    • June 27, 2021 at 2:09 AM
    • #14
    hi. Scooter. I did have the robot on when changing the batteries . Also. I had to change batteries in. Another robot fanuc. And the alarm bzal was still there on that one then ken the robot tech said it was missing the master/ cal. He showed me to re enter it and then the alarm went off but still had to be calibrated. .
    Probably need to do ot to this one what woyld be the procedure to master calibrate it ? Thanks
  • Skooter
    169
    2,026
    • June 27, 2021 at 2:58 AM
    • #15
    It depends on which axis/axes need calibration. Which axes have lost calibration?
  • ktmark
    8
    135
    • June 27, 2021 at 5:40 AM
    • #16
    won't kbow till. Monday but will let you know ..
