Hello guys, I have an error code refering to Dc-link type ( 38300 )in a S4C+ M2000 , does anyone know what it means ,attach photo ,thanks
S4C+ error Dc-link
Enio -
April 24, 2021 at 6:52 AM -
Just like the screen says, the DSQC358G DC-Link (rectifier) specified in the parameters is not found. We can assume the axis computer is not reading the type bits since it returned a zero. Make sure the DC-Link installed matches the parameters first. Try reseating the RJ45 connector second. Some of the RJ45 get brittle with age, seen a few fall apart. Used to carry a a few and a crimper back in the day.
Thank Skooter , we have try I-start in quiry mode and select Dc4 problem solved, but don't understand why loading with robinstall in silent mode doesn't recognize DSQC 358
Silent mode loads the defaults for the standard robot.
Query mode is where you enter non-standard variations such as a larger DC-Link or combo used when running ext. axes.
i looking for a translated list for S4 Rectifier
for example:
DSQC345A = DC0 = type code 16
i found this in the E-Drawings
