  4. ABB Robot Forum
DC link voltage too low warning
  • Dodo41
  • September 25, 2020 at 4:26 AM
  • Dodo41
    64
    Hello to everyone. I have 2 ABB Robots in my hand.
    MODEL IRB 6700
    CONTROLLER IRC 5.
    Both Robots are fed on the same power line.
    Suddenly, both robots started giving DC link voltage too low warning.
    Error Code 34401
    When I measure the energy coming to the robots, the problem does not appear.
    I turned off the main power and checked the Cables by hand, there was no slack.
    Robots have different failure times, so I don't think it's a sudden energy surge.
    And I don't think it's a cable problem either. Because this problem started suddenly, both robots could not have their cables loose at the same time.
    The description of the fault is written like this in the technical manual.
    34401, DC link voltage too low warning
    Description
    In drive module arg, the drive unit at unit position arg has a DC
    link voltage that is close to minimum limit.
    Consequences
    Operation will be possible but the system is close to a stopping
    error.
    Probable causes
    The incoming mains voltage to the rectifier unit is out of
    specification.
    Recommended actions
    1) Check for other hardware eventlog messages regarding
    mains voltage problem.
    2) Check incoming mains voltage. Change the mains tolerance
    min so that the mains voltage is inside the specified interval.
    3) Check that the correct voltage is selected with jumpers on
    the transformer (optional).
    4) Check all internal 3-phase components (main switch, mains
    filter, fuse, contactors) and cabling in the drive module.
    I tried all the possibilities but couldn't fix the problem.
    I am sharing a photo of the fault below.
  • Dodo41
    64
    • September 25, 2020 at 4:38 AM
    What are your suggestions for a solution?
    If the main drive is out of order, can I replace it with the spare part I have?
    What should I pay attention to when changing?
    There is a warning on the main drive.
    "Before replacing main drive system, remove any temp sensors adjacent to the heat sink."
    What are the sensors listed here?
    Since we have very intensive machines, I have no chance to make mistakes, what are the risks.
    Could software problems occur?
    Could there be a calibration problem in axes?
    The labels of the spare parts are like this.
    Is it a problem if I replace it?
  • Dodo41
    64
    • September 25, 2020 at 4:39 AM
  • Dodo41
    64
    • September 25, 2020 at 4:40 AM
    Edited once, last by Dodo41 (September 25, 2020 at 4:50 AM).
  • Dodo41
    64
    • September 25, 2020 at 4:47 AM
    These are all my thoughts.
    What are your solutions and experiences? Please share with me.
    Thanks everyone
  • Skooter
    172
    2,073
    • September 25, 2020 at 9:51 PM
    Is the problem intermittent or constant?
    Are the robots moving when this happens?
    This error can occur if there is a drop in one or more of the incoming 3-phase voltages. Since it happens with both robots on the same line, I would monitor that. If the robots are moving when this happens, their energy usage when the voltage drop occurs may be different enough to only fault one robot.
  • robot_ABB
    • November 17, 2021 at 1:25 AM
    How do you solve the problem? Can you help me? Thanks.
  • jimvw57
    • November 23, 2021 at 10:19 PM
    Take a good look at the capacitors on the power supply. if they show any signs of leaking replace them and have the 6-pac refurbished. You may have to do the drives too.
    Also check the contactors K43 and K42 (I believe) If they are older ones, it may be good to replace them and the external contacts. They control the incoming power
Similar Threads
  • Kawasaki UX150 A55 Help required to return to life
    • Nzhuhu
    • July 10, 2018 at 2:13 PM
    • Kawasaki Robot Forum
