Dear All
I am looking for RW 5.09
I am unable to create system from the backup as I dont have RW 5.09
The current system is on RW 5.09
Is there any other reason why I am unable to create a system from the backup
Regards
Alok
Dear All
Regards
Alok
Which version of Robotstudio are you using? You should just be able to update to 5.16.
I am using 6.01 .Also I just noted that the system backup does not have System.xml file .I believe my SD card gone corrupt .What should I do now
Did you see that file in other backups? I do not know when they implemented that. Which sd card? internal for the cpu or you are saving externally to your own sd card?
QuoteWhich version of Robotstudio are you using? You should just be able to update to 5.16.
i'am nout sure that is possible
5.09 => 5.16
i mean it is depend from the Hardware, e.g. type of main comuter DSQC 639 or DSQC623
