There is error: System.ArgumentException: Trigger type is "System.ArgumentException" exception.
System.ArgumentException:Cannot parse input:KS
This error occurs when reading the information by a program, Does anybody know how to solve it?
What is the controller version? Please provide more information, I do not fully understand what your issue is. Post code that is causing error.
The controller version is 6.07,the error is:
Unhandled exceptions: System.NotSupportedException:This flow does not support lookup operations
System.Net.ConnectStream.set_Position(Int64 value)
ABBElogSubscriber.ControllerSession.DeserializeElogResoure(Stream elogXml,String sqnum, Object robsn)
ABBElogSubscriber.ControllerSession.GetElogMessage(Stream elogUrl,Object robsn, Object IP, HttpWebCommunication_webcon)
ABBElogSubscriber.ControllerSession.Run(Object IP)
.. This error occurs when reading the information by a program,..
What does this mean?
The error massage of program.
Ahh, now it's clear
You should describe/provide the program, and the informations which the program should read.
Nobody here can know the program you use.
You didn't mention the software version.
The program is this picture,and the program should read ABB robot alarm message,The software version is 6.07. What's meaning the error?
