I Need to draw 24VDC power from the KUKA robot to run a maxon motor which is used as an end effector to spin a permanent magnet. This is a picture of the outlets ports in the KUKA arm and there is a black plastic connector with holes, any way to draw DC power so I don't have to use an external SMPS to run my Maxon motor?
KUKA Agilus DC power supply on arm
prakash saralaya -
November 29, 2020 at 3:57 AM -
kwakisaki
November 29, 2020 at 8:36 AM Moved the thread from forum General Discussion of Industrial Robots Only to forum KUKA Robot Forum. -
specs and connector pinout are all in the robot manual. this is meant for connecting sensors and small actuator, make sure your motor current draw does not exceed limits.
Thank you for your response, want to know what type of connector is this?
It looks like standard M12F-8
i would rather get cable assembly than try to get connector for it,
it is more compact and better suited for snug fit on the arm.
maybe something like SAC-8P-M12MR/ 1,5-PUR - 1522545
