My robot showing massage battery defective load test fail just I was disconnected the battery terminals for voltage checking after that it is showing battery defective load test fail any body tell me what is the reason.
KRC4
Indrasen -
October 20, 2020 at 3:14 PM -
reason?... well, isn't it obvious?
robot periodically does load test of the batteries to see if they can hold charge. if i recall interval is 36h or so and you just happened to disconnect them at the time of the test. so the load test failed as expected... next test should clear it.
