LIST OF TECHNOLOGICAL PACKAGES WITH KSS
  • Counterspeller
  • June 9, 2020 at 4:30 PM
  • Counterspeller
    102
    Hello everyone, everything good?
    Is there a list where I can check which version of the technology package is compatible with a specific KSS?
    For example which version of the grippertech package works with KSS 8.3.14?
    I searched the forum but found nothing.
    Thanks for any help.
    Edited once, last by Counterspeller (June 9, 2020 at 6:48 PM).
  • massula
    203
    8
    1,424
    • June 9, 2020 at 4:56 PM
    You can check the ReleaseNotes.txt file that is normally included with every Tech Pack.
  • massula
    203
    8
    1,424
    • June 9, 2020 at 5:02 PM
    On newer Tech Packs available only as KOPs, You can check this info on WorkVisual.
  • Counterspeller
    102
    • June 9, 2020 at 6:46 PM
    Quote from massula
    Thank's Massula, you're best.
    panic mode
    1,278
    13,079
    • June 9, 2020 at 8:12 PM
    you can also go to Xpert, search for your KSS and in result on the right side you will see list of everything associated with it including documentation and list of compatible options.
  • Counterspeller
    102
    • June 10, 2020 at 7:06 PM
    Thanks Panic Mode!
  • Tech Package
  • KSS
