Hi all,
Is there any way to remove the errors that come from the physical robot to appear?
As an example: Value of the nominal speed of the axis A1, moment of the gearbox of the axis 2 exceeded, ...
I had the LOAD_DATA to -1 (as far as I know this allows the robot to calculate the worst case), but now I've changed the Mass to the max allowed in the robot and put the COG in the right place... same behavior (in the real robot it works well). I've also reduced the speed a 20% and reduced the program override to 50% and even doing all this the errors keep appearing...
This never happens in the real robot and it makes it all slower to test when it happens in the virtual one.
Thanks!
