Looking over my backups and trying to figure out where the program call type (rsr,pns,style, other) are stored/logged and in which file is this info stored in, does anyone know which file that info is in? Also looking over section 5.2.5 of my Handling Tool Operations manual it shows how the Other Program select mode is setup but it doesn't describe how it receives the program call. Is it a UOP signal?
Other Program Select Mode
ericwiz7923 -
May 12, 2020 at 8:13 PM -
I appreciate the feed back, so after you set your chosen program with the detail key then essentially that program will run as long as you have the start condition signals and will stop when it receives the abort/stop conditions? I have more experience with PNS calls and a little RSR experience. This is the first time I noticed one of my lines is using a Other program call. Do you know which files of the back up would contain the $shell_wrk.$cust_name info?
It is probably buried in the system.va file. Open that file with a text editor and search for "Cust_Name" to see if it is in there.
Read this Post, great at explaining the different Program Select Methods.
Oh for sure. I've poked around One Robotics before, even bought his book. I like the way he explains a lot of stuff.
