KSS: 8.5.8
Robot: Various
Referring to this old thread that massula started about 5 years back, curious if there's been any follow up? (Source: KRC4 system messages manual)
Working on passing messages over TCP with the KRmsgNET TP. The following is a snippet from KRmsgNETSettings.xml, along with a comment for what the XML allows as far as customization. As you can tell, there's no option for message "severity" or importance. Best I see is %MessageType, which is not very granular.
Alternatively, there's the MBX_REC command. Documentation on this is... limited. Any pointers on what this function does, beyond the function definition EXTFCTP INT MBX_REC(INT MBX_ID :IN,STOPMESS MESS :OUT) from $OPERATE.DAT and $OPERATE_2.DAT? (source: KRC4 list of functions and subprograms)
<?xml version="1.0"?>
<KRmsgNetSaveConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Channels>
<Channel>
<Name>MsgRequest</Name>
<IPAdress>127.0.0.1</IPAdress>
<PortID>65002</PortID>
<MsgFormat>%HostName% %MessageTime:MM/dd/yyyy% - %ModuleName% - %MessageNo% - %MessageType% </MsgFormat>
<ConnectionType>Tcp</ConnectionType>
<CurrentFilter>
<FilterKeys>Info</FilterKeys>
<FilterKeys>Dialog</FilterKeys>
<FilterKeys>Event</FilterKeys>
<FilterKeys>Quitt</FilterKeys>
<FilterKeys>State</FilterKeys>
<FilterKeys>Wait</FilterKeys>
<FilterKeys>Config</FilterKeys>
</CurrentFilter>
<CustomFilter>
<UserMsg />
<TechnologyMsg />
<SystemMsg />
</CustomFilter>
<RequestSocket IsActive="true">
<PortID />
</RequestSocket>
</Channel>
</Channels>
</KRmsgNetSaveConfiguration>
Placeholder
Description
%HostName%
Configured network name
%Robname%
Configured robot name
%MessageTime%
Standard message time in the format: yyyy-MM-dd_ hh:mm:ss
Example: Display of the message time formatted
as year, month and day:%MessageTime:yyyy-MM-dd%
%ModuleName%
Module name of the message
%MessageNo%
Message number
%LocaleMessage%
Localized message
Contains the message text in the language set
on the robot controller as well as the parameters
belonging to the message.
The parameter designates
the specific value,
e.g. +/- for the direction of rotation, A1 ... A6 for
the robot axis.
%MessageType%
Message type
%EventType%
Message status
Add: The message is active from the time it is
sent to the external system.
Removed: The message was active and was
removed before the external system request-
ed the active messages.
Confirmed: The status “Add” was confirmed
while the external system was requesting the
active messages.
%MessageKey%
Message key without parameters
%LocaleMessageKey%
Message text in the language set on the robot
controller, without parameters
%Parameter%
All parameters
By default, the parameters are separated by
semicolons. If a different separator is to appear
between the parameters, it must be included in
the placeholder.
Example for formatting of the separator:
%Parameter:$%, if “$” is to be the separator.
