I need the system messages manual for KRC4.
I've already digged on the cds that comes with the controller but didn't find anything.
Anyone?
Anyone?
KSS_82_messages_en
Thanks, Jonson, but I was referring to the system messages/error manual.
That one which explain the meaning of the system messages, like kss 1497, for example.
Enviado de meu SM-N910C usando Tapatalk
You mean the manual which describe the error code? I have the manual for 5.4/5.5/6.5, but I do not have it for 8.x. The error code of C4 is different from C2.
Yes, this one. I've also have the previous manuals, but not for kss 8.x.
I imagine you have solved this issue since the post was in 2015 but I recently found myself with the same issue and I ended up using the help files loaded in the controller: C:\KRC\Help
You can copy the folder to your PC and browse the HTML files in en/index_SystemSoftware_VX.X.htm containing all messages and the related help just as it is shown in the controller with possible causes and solutions.
Just leaving this response in case it helps anyone, as I also couldn't find a pdf with this same information.
