Using the IR Vision Ethernet Port for Socket Messaging
  • Hello,
    I am working on a Fanuc robot that is using EthernetIO and socket messaging.
    I saw the system variable $HOSTC_CFG[1].$USE_VIS_PRT, and I was wondering if anyone knew if I could use this setting to be able to send TCP/IP messages through the ethernet port for the IR vision system?
    My target robot does not use IR Vision, but still has the ethernet port.
    Thanks,
    MiRobotGuy
    MI Robot Guy
  • MIRobotGuy
    Changed the title of the thread from “Using the” to “Using the IR Vision Ethernet Port for Socket Messaging”.
