R3-ia controller
is there a command to convert position register from Cartesian to Joint?
convert position register to Joint angles
- CPU_Malfunction
Manually? TP? Karel?
via TP program
Do you need that cartesian representation anywhere else, or you just want to have the joint representation regardless?
If the latter, you can just use this code to initialize a posreg in JOINT representation:
in this case, you get a PR which stores joint coordinates and holds 0 for each of them. Any operation on the coordinates will refer to joints, until you change the type of the PR.
For example, if you want to store a position in the PR in JOINT and then change one of its coordinates and move to the new position, you write sth like this:
This will initialize the PR[1] as described above, write the position stored in the P[1] to PR[1], add 60 degrees to the J6's coordinate and then move the robot to that new position stored in PR[1]. The effect will be moving the robot to P1 with +60deg difference in J6.
If you use the P[1] directly before the coordinate change operation, you can also do it like this:
This will first move the robot to P[1] (FINE is very important here!!!), store the current position of the robot as joints to PR[1], add 60deg to J6's position and then move the robot to that new position. The effect will be a movement to P[1] and then a J6 rotation by exactly +60deg.
What I would like to do is take a position that was captured already in Cartesian and then convert that PR to joint angles example:
PR[1]=LPOS
convert LPOS to JPOSI do realize that you can just read the position directly in the Joint angle format by using
PR[1]=JPOSbut I would like to convert the position possible when the robot is not physically at that position
I gave this a try, and it turns PR[1] into Cartesian representation.
Then I guess the fastest way is writing a simple KAREL program, as KAREL has a dedicated functions for converting JOINT to XYZWPR and the other way around. It could use an argument to specify which PR you want to convert...
I found that Karel will convert without the dedicated functions. You can do something like this and it will work:
Takes more lines of code than using a built-in I think But still worth knowing!
When you get the current location, just get both.
PR[1]=JPOS
PR[2]=LPOS
Then just use them as needed.
