Minimize HMI w/o Admin?
  • Hey Robot-Forum users,
    KSS 8.5.8
    KRC4 Compact controller
    DVI Monitor + USB Keyboard
    Appears one of our techs locked out Admin credentials on the KUKA HMI and promptly forgot the password. Nice. :rolleyes:
    W/ KSS 8.5, minimizing HMI comes with Admin credentials, no longer in expert. I have access to expert, but I don't have access to Admin. My plan, if I can successfully minimize the HMI or prevent the HMI from coming up, is to regedit the password back to default.
    Reading on a few other threads, it appears there's a key sequence you can use on boot to prevent the HMI from opening. I'm referrring to:
    smartHMI interface
    [SOLVED] KUKA KRC2 Windows fail
    I've given these a go, with no joy:
    - CTRL
    - SHIFT
    - CTRL+ESC
    Any clever ideas?
  • well, first thing is to find the culprit and punish him
    then make backup before touching or changing anything else. i normally make archive, diag and image. there is a lot of overlap/redundancy between them but i have seen backup fail too so more than one is a safe choice.
    then simple fix is to restore image using USB recovery stick... assuming you have one and this good backup image.
    another option is to connect HDD to a laptop using USB to SATA interface and edit whatever you like. not in front of robot but i think HMI is started by shortcut in Startup folder of the menu (C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup)
    so removing this should stop it from starting.
    if this is not the case you can try remote registry editor but this can be risky, i would rather temporarily rename "C:\KRC\StartKrc.exe" to "C:\KRC\StartKr_.exe" and put the HDD back into robot controller. This should prevent start of HMI and give you access to Windows.
  • once connected HDD to your computer, maybe just edit
    C:\KRC\USER\FeatureAuthorization.xml
    and change UserMode to 20 (or lower) for last line
    <FeatureRight ExactMatch="false" UserMode="30" Name="ConfigureAdvancedTP"/>
    • Helpful
    Wasn't able to find this specific XML, but I see what you're recommending.
    I did try playing around with C:\KRC\SmartHMI\Config\Authorization.xml, which gives the same user mode levels from 5 to 30. However, this didn't quite do as expected. Modified both "#ExpertProgrammer" and "#Administrator" values between 20 and 30, all it really seemed to do was make these options disappear from the user menu...
    However, I found another interesting workaround.
    From C:\KRC\UTIL\RuntimeTests, there is a DLL and config file that will allow a logging function to pop up on the SmartHMI.
    Copy/paste these files into both C:\KRC\SmartHMI and C:\KRC\SmartHM\Config, and you'll force the HMI to display a logging function on the bottom of the HMI. Will require a reboot w/ file reload, which you can force if you "Restore" a previous KUKA project. Just make sure you back up / image before doing so.
    From there, you'll be able to get into the desktop and use Start > Administrative Tools > Computer Management to reset the password.
