Programm digital in signal
  • Hello,
    I‘m a greenhorn at robotics but got a problem that needs to be solved.
    I got a screw unit at the robot to fix spare parts in milling machine. I put the Signal to the unit with DO X=[on]. The screw unit do his job and give a Signal back to the robot. On DI10 if it was okay and on DI11 if it was not okay. Program just can Go on if I Gotha signal on 10 (ok), if I got a signal on 11 (not ok) program have to stop and lightning bulb must be activated.
    How can I program this steps?
    Thank you in advance
  • Place your Ad here!
    • Helpful
    IF DI[10:]=1 AND DI[11]=OFF, JMP LBL[1] ;
    IF DI[10:]=0 AND DI[11]=ON, JMP LBL[2] ;
  • Don't use the wait statement unless you can't do anything else but wait.
    Always set in a loop and evaluate states. As shown above. You may need to answer other states like "Go Home", "Go maintenance", "Entry Request". I put these is a subroutine and look at them when I'm waiting on something.
